Need some general assistance
tpowell
Posted: December 22, 2004 at 10:12 AM / IP Logged
Greetings,
I've read the information made available here, but am still having a problem getting started in a general direction.
I'm trying to install an old IBM Thinkpad into my 1995 Supra and run a carpc to a dash mounted Xenarc touchscreen.
The issue I'm having is with the startup/shutdown wiring.
I plan to set the laptop to shutdown after on battery power (lack of 12v input) for 10 minutes.
THe problem I'm having is how do I turn it back on when the 12v input is reapplied?   Do I need to physically disassemble the laptop and wire to the power button?
Last question, are there any pre-manufactured products that I could use in place of any custom-made solutions you all might recommend.   These are preferred to keep build time to a minimum.
Thanks in advance,
Aldebaran
jugador
Member - Posts: 9
Posted: December 22, 2004 at 12:28 PM / IP Logged
Hey your not gona find to much info on that here. But check out this site  www.mp3car.com  its a pretty good forum when it comes to carputers. Hope that helps you out.
It Can always be Done, The question is do you have the MONEY!!!!!!!!!!!!
tpowell
Posted: December 22, 2004 at 12:58 PM / IP Logged
Thanks! I'll check that out instead.
