2002 Pontiac Grand AM SE
malucyk
Copper - Posts: 56
Posted: October 17, 2002 at 7:10 PM / IP Logged
Wiring diagram for a 2002 Pontiac Grand Am SE.
Thanks again
Matt
Moderator - Posts: 12,488
Posted: October 17, 2002 at 8:44 PM / IP Logged
|              12V|red                 |+  |ignition harness *1         |
|          STARTER|yellow              |+  |ignition harness *1         |
|         IGNITION|pink                |+  |ignition harness *1         |
|  SECOND IGNITION|dk. green           |+  |ignition harness *1         |
|        ACCESSORY|orange              |+  |ignition harness *1         |
| SECOND ACCESSORY|brown               |+  |ignition harness *1         |
|       POWER LOCK|white               |-  |drivers kick panel in       |
|     POWER UNLOCK|same wire           |*2 |a black plug                |
|       LOCK MOTOR|gray                |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passenger kick panel        |
| PARKING LIGHTS +|brown               |   |passenger kick or column    |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|dk. blue & pink     |*3 |steering column             |
|     DOOR TRIGGER|*4                  |-  |*4                          |
| DOME SUPERVISION|white               |-  |dash light or column        |
|  TRUNK/HATCH PIN|ORANGE / black        |-  |trunk light                 |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |drivers kick panel          |
|       TACHOMETER|white or PURPLE / wht |   |ignition coil or ECM *5     |
|      SPEED SENSE|dk.GREEN / WHITE      |   |ECM *5                      |
|       BRAKE WIRE|lt. blue            |+  |at the switch               |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|dk. grn & purple    |+  |steering column             |
|  LF WINDOW UP/DN|dk. blue - gray     |A  |drivers door switch         |
|  RF WINDOW UP/DN|lt. blue - tan      |A  |drivers door switch or kick |
|  LR WINDOW UP/DN|dk. green - pur/wht |A  |drivers door switch or kick |
|  RR WINDOW UP/DN|lt. green - purple  |A  |drivers door switch or kick |
| SUN RF OPN/CLOSE|blue - green        |A  |sunroof motor               |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|orange              |+  |at radio                    |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|yellow              |+  |at radio                    |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|dk. green           |   |at radio                    |
|       LF SPEAKER|tan - gray          |   |at radio or LF speaker      |
|       RF SPEAKER|lt. grn - dk. grn   |   |at radio or RF speaker      |
|       LR SPEAKER|brown - yellow      |   |at radio or LR speaker      |
|       RR SPEAKER|dk. blu - lt. blu   |   |at radio or RR speaker      |
Notes:
NOTE:  This vehicle has the passlock II immobilizer system  *1 Remove the radio, without unplugging it, to access the ignition harness.  *2 Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.  *3 Requires a high current ground. Use a relay.  *4 The lt. GREEN/ black is located in the drivers kick and catches only the drivers door.  The lt. blue is located in the harness coming from the drivers running board going under the drivers seat and it catches all other doors.  Use both door trigger wires and diode isolate each. On the 2 door the lt.blue is in the passenger kick.    *5 The ECM is located under the left side of the dash to the left of the column.
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
