how 2 power 2nd accessory wire
Mharvey
Copper - Posts: 76
Posted: December 26, 2004 at 10:42 AM / IP Logged
i have a 2001 ford f150 with a Directstart cs423 remote start. i have 1 acc. wire hooked up (it controls the heat and ac) but i need to know how to power the 2nd acc. which controls the radio and other acc. The remote start only has 1 accessory output. how do i go about wiring a relay to power the other wire???? I know what wire it is but dont know how to connect the relay
KarTuneMan
Platinum - Posts: 7,056
Posted: December 26, 2004 at 4:48 PM / IP Logged
Use your "groung while running" output on pin 85.
pin 86 and 87 get 12volt fused @ 20-30amps  pin 30 goes to your acc. wire
I use astroflex....they have a dedicated programable built in relay    PLUS 4 programable outputs  of wich any can be programed for start acc ign.   dome pulse before and after......just COOL
good luck my friend
