remote start / alarm wires
dankadad
Member - Posts: 13
Posted: December 26, 2004 at 10:49 PM / IP Logged
hi, looking to install remote start / keyless entry / alarm (DesignTech #23927) in 2005 Ford Freestar minivan.
looking for wire color code and location data for 2005 Ford Freestar.
also which type of security system does this vehicle have and best way to over ride for remote start.
thanks
bb
KarTuneMan
Platinum - Posts: 7,056
Posted: December 27, 2004 at 12:44 AM / IP Logged
12volts red (20A), lt. GREEN/ pur (20A) +  ignition harness
Starter dk. green  +  ignition harness
Second Starter N/A
Ignition WHITE/ yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory PURPLE / orange  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense lt. GREEN/ purple  -  ignition harness
Power Lock WHITE/ purple  -  SJB, black 26 pin plug, pin 3
Notes: The SJB (Smart Junction Box) is part of the fuse box under the driver side dash. The black 36 pin, and the blue 52 pin plugs are on the front. All the other plugs are on the back.
Power Unlock dk. blue/lt. green  -  SJB, black 26 pin plug, pin 1
Lock Motor RED / orange  5wi SJB, black 5 pin plug, pin 3
Unlock Motor yellow  5wi SJB, black 5 pin plug, pin 1
Parking Lights+ each controlled separately
Parking Lights- see DirectFax document 1072
Hazards WHITE/ red  -  SJB, blue 52 pin plug, pin 24
Turn Signal(L) use hazards wire
Turn Signal(R) use hazards wire
Reverse Light WHITE/ yellow  +  SJB, gray 52 pin plug, pin 13
Door Trigger use dome supervision wire
Dome Supervision ORANGE / white  -  SJB, gray 26 pin plug, pin 21
Trunk/Hatch Pin use dome supervision wire
Hood Pin PURPLE / orange    SJB, black 52 pin plug, pin 15
Notes: The hood pin wire rests at ground and goes to open circuit with the hood open.
Trunk/Hatch Release yellow  -  SJB, gray 26 pin plug, pin 15
Power Sliding Door wht/lt grn (L), lt grn/red (R) -  SJB, gray 26 pin plug, pins 16, 14
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. blue/black  -  SJB, black 26 pin plug, pin 9
Disarm No Unlock see factory alarm disarm
Tachometer NOT red  ac  ignition coil or any fuel injector
Wait to start N/A
Brake Wire RED / lt. green  +  SJB, black 36 pin plug, pin 5
Parking Brake RED / yellow  -  SJB, black 52 pin plug, pin 50
Horn Trigger dk. blue  -  SJB, blue 52 pin plug, pin 39
Memory Seat 1 BROWN / lt. green  -  SJB, black 52 pin plug, pin 9
Memory Seat 2 BLACK/ orange  -  SJB, black 52 pin plug, pin 8
Memory Seat 3 N/A  -
remote start / alarm wires -- posted image.
Immobilizer Bypass Module:Required: YesType: SecuriLockPart #: 556S, 556U, or 555U
Notes: Standard on all models.
dankadad
Member - Posts: 13
Posted: December 27, 2004 at 12:53 PM / IP Logged
thanks, wish me luck
bb
