Novice needs help
breagle
Posted: December 26, 2004 at 11:41 PM / IP Logged
Hey guys...
Im trying to add a sub and amp to my 2003 suburban(w/bose).
I have a few questions and was hoping someone could help.
1. My amp has "speaker level inputs." This means I can tap into a speaker and get a signal without getting into the dash and running RCA's back to the amp, right????
2. If #1 is correct, is there a way to verify which color wire is + or -? There are a brown and a yellow. I think from what I have read, brown is +, but not sure.
3. Anyone have any ideas for my turn on wire? There is a wad of wires running through the back of the truck. Is it possible I could turn the key to "on" and see which one has power, and tap into that?
Hope thats not too much....thanks in advance for any help
Sancho
Copper - Posts: 162
Posted: December 26, 2004 at 11:45 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=27878&PN=1&fid=2&PR=3 go there first to  find your wiring
Head Unit:Alpine CDA 9835
6.5 MB Quart Pce 210
Amp:JBL 80.4
Amp:JBL 1200.1
Sub:Adire Brahma 12 MKII
KarTuneMan
Platinum - Posts: 7,056
Posted: December 27, 2004 at 12:03 AM / IP Logged
PAC and Soundgate make adapters for addind an aftermarket amp to a Bose system
You can Google soundgate and PAC to do some investigating.  Dont try and use "speaker leval" to input to your amp......You wont be happy with the sound
KarTuneMan
Posted: December 27, 2004 at 12:04 AM / IP Logged
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
