2002 toyota rav 4
amador
Copper - Posts: 108
Posted: October 18, 2002 at 9:37 PM / IP Logged
hey thier everyone i need some help once again in looking for a diagram for a 2002 toyota rav four for a alarm hook up please do help thank a million.
sonic boom
Platinum - Posts: 12,488
Posted: October 19, 2002 at 10:00 PM / IP Logged
ENJOY !!!! amador.....
|              12V|white & BLACK/ red   |+  |ignition harness            |
|          STARTER|red                 |+  |ignition harness            |
|         IGNITION|black               |+  |ignition harness            |
|  SECOND IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/orange         |-  |DKP, 14 pin plug in pin 6   |
|     POWER UNLOCK|blue / YELLOW *1      |-  |DKP, 14 pin plug in pin 13  |
|       LOCK MOTOR|blue/orange         |   |DKP, 14 pin plug in pin 2   |
|     UNLOCK MOTOR|blue/red            |   |DKP, 14 pin plug in pin 7   |
|    DISARM DEFEAT|blue/red            |   |DKP, harness to the rear    |
| PARKING LIGHTS +|green or grn/red    |   |headlight switch            |
|       HEADLIGHTS|RED / black           |-  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|tied in with doors  |   |                            |
|TRNK/HTCH RELEASE|blue                |5wi|PKP, harness to the rear    |
|       TACHOMETER|black               |   |data link connector *3      |
|      SPEED SENSE|PURPLE / white        |   |ECM behind glove box        |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blu/org(L),blu/blk(H|+  |steering column             |
|  LF WINDOW UP/DN|yellow - green      |A  |driver window switch        |
|  RF WINDOW UP/DN|grn/org - blu/wht   |A  |DKP, 13 pin plug            |
|  LR WINDOW UP/DN|blu/blk - blu/red   |A  |DKP, 13 pin plug            |
|  RR WINDOW UP/DN|RED / yel - RED / blu   |A  |DKP, 13 pin plug            |
| SUN RF OPN/CLOSE|blk/wht - blk/yel   |A  |at motor in roof            |
|   SUN ROOF LIMIT|red, green          |-  |at motor in roof            |
|        RADIO 12V|blue / YELLOW         |+  |radio                       |
|     RADIO GROUND|brown               |-  |radio                       |
|     RADIO SWITCH|gray                |+  |radio                       |
| RADIO ILLUMINATE|green               |+  |radio                       |
|       LF SPEAKER|pink - purple       |   |radio                       |
|       RF SPEAKER|lt. green - blue    |   |radio                       |
|       LR SPEAKER|black - yellow      |   |radio                       |
|       RR SPEAKER|red - white         |   |radio                       |
Notes:
NOTE: Some models have an immobilizer system  *1 Unlock requires a double pulse.  *2 The door trigger wires are at the passenger side junction box behind the glove box. The driver door trigger is RED / yellow in a 10 pin plug in pin 3, the front passenger door is RED / white in a 20 pin plug in pin 5, and the rear doors and hatch is RED / white in a 10 pin plug in pin 2.  *3 The data link connector is below the driver side fusebox. The tach wire is the black wire in pin 9.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 19, 2002 at 10:01 PM / IP Logged
I work on at least 5 RAV4s a week..... I have a bunch of tricks for those...........are you doing alarm only, or remote start too?
Sound Pressure
Silver - Posts: 711
Posted: October 20, 2002 at 12:49 AM / IP Logged
What kind of tricks do you have for the Rav4's?2002 toyota rav 4 -- posted image.
Sound Pressure
amador
Copper - Posts: 108
Posted: October 20, 2002 at 10:58 PM / IP Logged
thanks everyone for all your help again thanks a million
sonic boom
Chris Luongo
Posted: October 20, 2002 at 11:49 PM / IP Logged
Pry the door sill off.  You'll see a white plastic guide, with various wires running under the driver's seat.  Running from the front of the car and going underneath the seat, GREEN / WHITE is the brake wire.  Running out from the seat and toward the rear of the car, green is parking lights, and red is door trigger..........the door trigger there is one wire that catches all the doors, including the tailgate!  It's not affected by the domelight delay either.
The BLACK / YELLOW second ignition wire powers the climate controls, and the blue/red accessory wire powers the radio.....accessory wire is not needed for remote start.
The blue/orange and blue / YELLOW power lock/unlock wires are tested by twisting the key in the driver's door lock cylinder, not by operating the pushbutton on the door.
The door unlock is two-step, not "double pulse."  The first pulse to the blue / YELLOW unlocks the driver's door only; a second pulse does all the other doors.
If you have an alarm that won't put out a double pulse, do this:  Split the alarm's unlock output with two diodes.  One goes to the unlock wire that tests off the switch on the driver's door, the other goes to the Unlock Detection wire......this is a wire that shows a ground all the time the door is unlocked..................I forget the colors of these two wires, but they're in the driver's kick coming in from the door.  Alternately, you can run a wire over to the passenger's kick...... the key-cylinder wire on that side unlocks all doors with a single pulse.
"trunk/hatch release" info should be disregarded........there's no hatch release in this car.......the tailgate simply unlocks with all of the other passenger doors.  At least this is true on all the U.S. models I've worked on.
If you're only doing a keyless or an alarm, you can get the wires you need right in the driver's kick, without having to take the dash off.  In a large plug with wires going into the driver's door, RED / white is constant, and black is ignition......but the black wire retains power unti the car door is opened............that's just fine under normal conditions, but the installer must leave the door open while he's cycling the ignition key on and off to program the alarm's settings.
So far, the handful of 2003s I've done appear to have exactly the same wiring as the 2002s.
