98 Toyota Camry & PhoenixDigital PD175
vl3tfun
Member - Posts: 8
Posted: December 28, 2004 at 8:30 PM / IP Logged
Someone please shows me where I can find Tach wire, Trunk release wire, the power supply wire to the Distributor, turnsignal light wire in my Camry 98 LE ? Thank you !
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2004 at 7:19 PM / IP Logged
Tach   BLK/ORNG @ecm behing the glove box
The car should have a manual trunk release
By turn signal, do you meen parking lights?  If so, green POS wire on the bottom of the fuse box in a white connector
vl3tfun
Member - Posts: 8
Posted: December 30, 2004 at 10:03 PM / IP Logged
Thank you all for the info.  I had done the installation myself and it is working perfectly. But I am wondering that there is a negative input handbreak wire which if I don't ground it, the car starter function won't work.
vl3tfun
Member - Posts: 8
Posted: December 30, 2004 at 10:05 PM / IP Logged
"the car starter" which I meant was "the remote car starter". thank you.
