1992 Montero Parking Lights
ziplok
Posted: December 29, 2004 at 6:44 PM / IP Logged
I'm installing an alarm on the Montero. I stuck at the parking lights. The diagram says the parking lights wire is at the driver side firewall and it is GREEN / WHITE. The only problem is that there are several wires fitting that discription. How do I find the right one? Any help is appreciated.
Captanham
Silver - Posts: 365
Posted: December 30, 2004 at 6:30 PM / IP Logged
you really should learn to test most things unless you are 100% sure about them with a meter, you should never rely just on books or the internet for your rs insalls, there are hundreds of vehicles and hundreds of sites with wire charts, it wont take long before you come across an error somewere, trust me,,, so it's always better to spend that little bit of time and check things you aren't sure about, it's better then blowing fuses, frying wires, computers, who knows.....
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
