2003 Dodge Caravan remote start/keyless entry
dlsargent
Posted: December 29, 2004 at 9:00 PM / IP Logged
2003 Dodge Caravan on the wiring information what is a directfax document #1083 ,1082 and 1076. How do i get this information.
6979ta
theronsmith
Member - Posts: 36
Posted: December 29, 2004 at 9:19 PM / IP Logged
I dont think you can get them unless you have a username and password for the directechs site.
chevy II
theronsmith
Member - Posts: 36
Posted: December 29, 2004 at 9:35 PM / IP Logged
I belive that it is the 2003 and up that get kinda hard.........With stuff like a starter wire that needs a negative pulse with a resistor (make sure you use a relay not the negative starter output) im not shure what size of resistor you have to use.. I think you also have to get power straight from the battery. And if you are doing locks they are multiplex (negative pulse through the same wire with different resistors for lock and unlock....also use relays not the negative outputs on the unit. Make shure that when you get your ground source for all the relays you find the best ground possible. Hope this helps. I wish i could help more with the right resistor sizes. This should at least get you in the right direction.
chevy II
Captanham
Silver - Posts: 365
Posted: December 30, 2004 at 6:24 PM / IP Logged
the starter has two wires, a yellow, and a PURPLE / brown wire,,, the yellow is just hooked up and then the other wire needs ground threw a 180 ohm resistor
violet / green wire is the lock unlock wire, it needs ground threw a 2k ohm resister for unlock and threw 5.2k resister for lock, the resistances must be within 5 % for it to work
The parking lights are negative trigger through a 2.1K ohm resistor also, WHITE/ brown wire,, hope this all helped
Bad Boys Customs
    audio - video - security
If you use it. Suport it. Donate to the 12 volt!
Captanham
Silver - Posts: 365
Posted: December 30, 2004 at 6:26 PM / IP Logged
and it shouldn't be a REALLY big deal about were you get your ground, i mean,, get a good one, but you can use the grounds comming out of the unit for the door locks, it will be fine, and if you have the right kind of remote start you should beable to switch polarity on the output for the parking lights to so that you can use that,,, just so you don't have to do an install with 7 relays ya know?
Bad Boys Customs
dlsargent
Posted: December 31, 2004 at 2:13 PM / IP Logged
  I have a BOA model 265B remote start system with keyless entry. From Target.
6979ta
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
