amp wiring ?
bluetruck
Copper - Posts: 115
Posted: December 31, 2004 at 7:34 AM / IP Logged
i want to run an Adire Shiva 12" Sub off an MTX Thunder 421D
the Sub is dual 8ohm V.C.
the amp runs 420w RMS x 1 @ 2 ohm.
how can i wire it to run 2 ohms? i know if i wire it amp +positive+ to both VC +positives+'s  and same w/ the negative it will run 4ohms, is there a way to get it to 2 ohms without adding a second subwoofer? thanks. ~Ryan
also, if anyone knows any websites that have shiva's in stock please let me know! (backordered till late january!)
DYohn
Platinum - Posts: 10,741
Posted: December 31, 2004 at 8:50 AM / IP Logged
Nope.  Wire in parallel and you get 4 ohms.  It will work fine.
uthinkuknoaudio
Silver - Posts: 760
Posted: December 31, 2004 at 9:08 AM / IP Logged
Remember the shiva doesn't require a lot of power. You want that amp to run @ 4 ohms because the shiva is a dual 8 ohm woofer, so just wire it down to 4 ohms and you'll be fine.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
blg748
Copper - Posts: 194
Posted: December 31, 2004 at 9:18 AM / IP Logged
but how is this POSSIBLE because his amp  p uts out 420RMS *1 but at 2 oHms not 4ohms how will he be able to run it like this ? i dont understand beacuse i plan on dropping in a  adire shiva in a cpl mo nths and selling the 12w3v2 i have.
stevdart
Platinum - Posts: 5,816
Posted: December 31, 2004 at 9:38 AM / IP Logged
http://www.bcae1.com/ohmslaw.htm for a peek at why your amp will perform with a 4 ohm load.  An amplifier doesn't care what impedance your speakers are, it just reacts to the impedance load that the speakers put on it.  When you put a 2 ohm load on it, the specs claim that it will output 420 watts.  Then if the load were double that (double the resistance) at 4 ohms, Ohm's Law tells us that the amp will output half the power.  So it should make about 210 watts into 4 ohms.  http://www.mtxaudio.com/caraudio/products/amplifiers/thunder421D.cfm
(...or did I misinterpret  your question?...)
