Remote Start for 93 Explorer XLT
Lordmarcus42
Posted: January 02, 2005 at 3:51 PM / IP Logged
I'm installing a Polarstart EX-2520TW (aka: Autostart AS-2520TW)Remote Starter into my 93 Ford Explorer XLT (w/o factory keyless)and just want to check 2 things before I hook up the "crank/starter" wire:
1) I noticed that when the ignition switch is in the "run" position, there is a constant 5V going down the "starter" (RED / Light Blue) wire and 12V when the ignition is in the "start/crank" position. Do I need a diode or relay between the vehicle's harness wire(RED / Light Blue) and the remote starter wire (6Pin Harness Purple wire) to prevent the constant 5V from feeding back into the remote starter and causing damage to it? And...
2) Do I need a 40A relay between the vehicle's 2nd Ignition wire (BLACK/ Green) and the Remote Starter's wire (6pin Harness Green wire)?
Thanks in Advance,
Marcus.
Craig3708
Copper - Posts: 155
Posted: January 02, 2005 at 7:25 PM / IP Logged
No to both questions....
Ford
Explorer
1992-1994
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / LIGHT BLUE
IGNITION SWITCH HARNESS
Ignition  #1:
RED / LIGHT GREEN
Ignition #2:
GRAY / YELLOW (# AWG)
IGNITION SWITCH HARNESS **
Ignition  #3:
GRAY / YELLOW-2WIRES
Accessory:
BLACK/ GREEN
Brake  Light:
GREEN (+)
AT SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
TAN / YELLOW
AT COIL (3.0L) *
Parking Lights:
BROWN
(+) AT LIGHT SWITCH
Headlights:
RED / YELLOW (+)
HEADLIGHT SWITCH OR BEAM SELECT SW.
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2.3L Tach Wire Is BLACK / YELLOW At EDIS Module. On All Explorers Except 3.0L Tach Test Connector Can Be Found On Passenger Rear Corner Of Engine Compartment Near The Blower Motor. ** See Note #127 - Ford Ignition Switch Connection Diagram.
Ford
Explorer
1992-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
2 YELLOW OR 2 GREEN
OEM Alarm Disarm:
LT.GREEN/ PURPLE (-)
DRIVERS KICK PANEL
Dome  Lights/Superv:
BLACK/ LIGHT BLUE
(+) AT PIN SWITCH
OEM Horn:
DARK BLUE (+) OR
YELLOW/LIGHT GREEN (-) IN COLUMN
Power  Lock:
PINK / YELLOW
DRIVER'S KICK PANEL ***
Power  Unlock:
PINK/LIGHT GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ LIGHT BLUE
(+) AT PIN SWITCH
Lordmarcus42
Posted: January 02, 2005 at 9:48 PM / IP Logged
Thank you for your quick response.
Marcus
