No Power To Radio?
caddyMike
Posted: January 15, 2005 at 12:12 AM / IP Logged
I was trying to put in my pioneer in my 98 Cadillac Deville but there is no power to it. I have two extra wires from the wire harness-Orange and Blue. Blue for the power antenna it says on the harness. The thing is there is no orange wire in the pioneer harness and the blue wire in the pioneer harness is for a remote it's tagged. The cadillac has a power antenna but I can't get any power to the radio. Can anyone help it wasn't a fuse because the factory still works. I don't know if I have to connect multiple wires together. Please help.
Mike with the Deville
psypathic
Member - Posts: 13
Posted: January 15, 2005 at 2:05 AM / IP Logged
Check the fuse on the unit a make sure the yellow and red is going to a 12 volt suply.
slammedb5
Copper - Posts: 103
Posted: January 15, 2005 at 3:11 AM / IP Logged
Make sure you are matching up CORRECT wires (regardless of color) to the new H/U. In most applications, red in your car doesn't mean red for the H/U. Likewise for yellow and black. Good luck.
EK Civic
security
no audio
caddyMike
Posted: January 15, 2005 at 12:53 PM / IP Logged
Thanks but what about the power antenna or that orange wire? The colors do match Red & Yellow because the radio is tagged and the harness came with a wire list.
esmith69
Gold - Posts: 1,511
Posted: January 15, 2005 at 9:41 PM / IP Logged
you know you have to press the source button to make it turn on the first time after it's connected, right?
Ethan
Donate to the12volt.com
auex
Platinum - Posts: 5,041
Posted: January 15, 2005 at 9:47 PM / IP Logged
Damn, that is what I was going to say. But anyways check your ground too then. There maybe a fuse on the radio itself that you need to check. If everything checks out then your radio is bunk.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Javelin3o4
Copper - Posts: 239
Posted: January 16, 2005 at 12:49 AM / IP Logged
If you have one just bust out a DMM and test the power and ground connections.
slammedb5
Copper - Posts: 103
Posted: January 16, 2005 at 4:31 AM / IP Logged
I think you are retarded and didn't connect your wires properly. Hey, buy a DMM and try again. Oh, and by the way, don't ever question me again, retard.
EK Civic
security
no audio
tech460
Copper - Posts: 118
Posted: January 16, 2005 at 9:46 AM / IP Logged
Do you realize the 98' Caddy Deville is class 2 and there is no accessory in the harness? Do you understand that most likely you have a factory amp in the car and you won't be able to use it.  Take a look under the spare tire cover for a sticker labeled "service identification". In that mix of numbers and letters look for one of these codes; UW6, UQ6, UQ4. Post back with the results and will give the answer to all your problems.
caddyMike
Posted: January 16, 2005 at 2:58 PM / IP Logged
Tech 460 Thanks, the code listed is UW6. I don't have a DMM but did try the source button and slammedb5 you don't think I already stripped and reconnected it's not my first radio buddy.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
