bypass for 03 Mazda 6
way2hard2contro
Member - Posts: 26
Posted: January 18, 2005 at 3:54 PM / IP Logged
Which bypass would you recommend for a 2003 Mazda 6s?  I am planning to go with either a Viper 791 or Ultra Start 4256M.  Thanks for the help.
mo12v
Posted: January 18, 2005 at 9:46 PM / IP Logged
OMEGA makes a IB-PKF-3 ( No key Required )  or PASS-4 Transponder where you need a Coded Key to put in box.
DEI makes a ByPass also.
There are others, but most are licensed thru OMEGA
MO
cutter1122
Copper - Posts: 103
Posted: January 18, 2005 at 10:19 PM / IP Logged
way2hard2contro
Member - Posts: 26
Posted: February 04, 2005 at 1:49 PM / IP Logged
How about the DEI 555P?  I see that one is listed for vehicles with PATS.  Does the 555P require a key be left with the module or just 2 keys to program?
extreme1
Silver - Posts: 1,070
Posted: February 04, 2005 at 6:46 PM / IP Logged
555P is for older generation PATS
PKF3 is the only no key required module that I use for the new ford/mazda keys
Shaughn Murley
Visions Electronics
Red Deer, Alberta
