2001 cavailer factory alarm bypass
jtinman
Posted: January 18, 2005 at 7:20 PM / IP Logged
Hello
Installed a remote start on a 2001 cavalier.
This vehicle is equipped with a "content theft
deterent". If you lock the doors with the factory
keyfob then try and remote start the horn and lights
flash.   --the info I have states that when the ignition
wire is powered up on remote start, this shuts down the theft system ---not the case..
Anyone know which wire to groundpulse at the bcm to disarm this system on remote start-up??
Sexified
Copper - Posts: 87
Posted: January 18, 2005 at 8:33 PM / IP Logged
make sure that you powered up the brown wire(acc.) as a second acc. pink for the ignition and white for second ignition...if it has it. otherwise evrything should be 100%.
sweet.
cutter1122
Copper - Posts: 103
Posted: January 18, 2005 at 8:46 PM / IP Logged
2001 cavailer factory alarm bypass -- posted image.
cutter1122
Copper - Posts: 103
Posted: January 18, 2005 at 9:58 PM / IP Logged
disarm with relay
30 : ignition wire : pink
85 and 87 : +12 volts
86 : to disarm wire (-) from remote starter , add a diode (cathode to the remote)
next wire need to be install on the disarm wire between the last diode and the remote and then connect it to (-) trigger wire at Passlock bypass unit
add a diode  (cathode to the remote "disarm wire")
cutter1122
Copper - Posts: 103
Posted: January 19, 2005 at 12:36 AM / IP Logged
