Autostart Username
plucky78
Posted: January 19, 2005 at 3:56 PM / IP Logged
I need schematics from autostart but we need to be a dealer to access them, does anyone have an autostart username & Password ? Thanks in advance.
Moderator - Posts: 12,488
Posted: January 19, 2005 at 4:10 PM / IP Logged
What manual do you need ? I'll see what I can do for you.
plucky78
Posted: January 19, 2005 at 6:33 PM / IP Logged
wiring for a 2001 Toyota Celica (for a remote starter), the one from directech doesnt contain enough details.... there are like 200 wires connected to the ecm, and I know autostart offers location and often pictures where the wires are located.
kgerry
Platinum - Posts: 3,455
Posted: January 19, 2005 at 6:43 PM / IP Logged
just curious... did you honestly expect an authorized dealer to just give you his user name and password????
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
plucky78
Posted: January 19, 2005 at 7:07 PM / IP Logged
well, I used to have one but they changed the site last year and it doesnt work anymore
auex
Platinum - Posts: 5,041
Posted: January 19, 2005 at 7:19 PM / IP Logged
There should be no reason that you would need any other info other then the info from DEI to do a remote start. Use your meter.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
plucky78
Posted: January 19, 2005 at 7:24 PM / IP Logged
if you saw the interior of that car you wouldnt say that, there is no space and a lot of wires of the same color, of course i use my meter, i just wanted a little help.... thanks anyway
forbidden
Platinum - Posts: 5,353
Posted: January 19, 2005 at 9:49 PM / IP Logged
Some of the sites also require you to have a serial# of th eunit you are working with, no serial#, no access.
Montrealler
Copper - Posts: 155
Posted: January 19, 2005 at 10:37 PM / IP Logged
Let's say ....
I got have too good knoweldge about Autostart.
All user/Install Guide are free of access thru the web site.
If you bought any product from the Autostart Family keep the serial number (12 Digits) for a free web access to their Database.
Also to be Kind there is a wiring chart
Any question About Autostart Ask Me!
12V|blk/red & white |+ |ignition harness            |
STARTER|BLACK/ white |+ |ignition harness            |
IGNITION|BLACK/ orange *1 |ignition harness            |
SECOND IGNITION|blue/red *4 ignition harness
ACCESSORY|gray   |+ |ignition harness            |
POWER LOCK|brown      - |passenger kick or BCM *2    |
POWER UNLOCK|yellow/black - passenger kick or BCM *2    | PARKING LIGHTS +|use the (-) wire    |
PARKING LIGHTS -|lt. green steering column             TRUNK/HATCH PIN lt. green -|trunk light or BCM *2       FCTRY ALARM ARM|arms with lock      |
FCTRY ALRM DISARM|disarms with unlock |    TACHOMETER|BROWN / white|rear of instrument cluster |
BRAKE WIRE|GREEN / WHITE + |brake switch
HORN TRIGGER|blue/black - |steering column or BCM *2   WIPERS|blu/yel & blu/orn   |+ |steering column|
SUN RF OPN/CLOSE|not recommended     |
Notes:
*1 When doing remote start, this wire must be isolated from the keyswitch with the ignition relay. *2 The BCM is located just to the right side of the radio. Remove the radio to access. *3 To avoid dome light delay, use RED / yellow at the driver door pin for the driver door and red at the passenger door pin for the passenger door. Isolate each door trigger with diodes. *4 There are 2 blue/red wires in the ignition harness. The correct ignition wire is the heavier gauge one and it has 1 silver hash mark. The incorrect wire has 2 silver hash marks.
Yes I'm Back 2006...
Thursday, July 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
