multiple sirens
Ratt
Member - Posts: 14
Posted: October 27, 2002 at 9:12 AM / IP Logged
i read a post were an installer mentioned puting on more sirens,i want to put 3 sirens on 2 exterior and 1 interior,is there anything i need to do to the output of the alarm so as not to drag down the other sirens or overload the output and draw to to much through it
....thanks for any info......
Player69
Silver - Posts: 504
Posted: October 27, 2002 at 3:29 PM / IP Logged
Use a relay.
Platinum - Posts: 12,488
Posted: October 27, 2002 at 4:11 PM / IP Logged
Wire up a 30/40 amp relay in this configuration: Use the first configuration if your SIREN wire outputs a (+) pulse and the second if it outputs a (-) pulse:
  • POSITIVE INPUT -----> POSITIVE OUTPUT
    • 87 - constant 12 +
    • 86 - Chassis Ground
    • 30 - To other sirens (+) wire
    • 85 - (+) siren output wire
    • 87a- NOT USED
  • NEGATIVE INPUT----> NEGATIVE OUTPUT
    • 87 - Chassis ground
    • 86 - constant 12 volts +
    • 30 - To other sirens (-) wire.
    • 85 - (-) output siren wire
    • 87a - NOT USED
  • Jeff
    Ratt
    Member - Posts: 14
    Posted: November 06, 2002 at 7:34 AM / IP Logged
    thanks guys for the help
    Posted: November 06, 2002 at 7:48 AM / IP Logged
    No problemo
