97 eclipse wiring diagram
mitsushocker
Member - Posts: 17
Posted: January 28, 2005 at 9:31 PM / IP Logged
hey i need a diagram for a 97 eclipse gs i am doing an alarm install on.  thanks for the help97 eclipse wiring diagram -- posted image.
1997 Mitsubishi Eclipse GS
leave a msg after the beep beep.....
mitsushocker
Member - Posts: 17
Posted: January 28, 2005 at 9:35 PM / IP Logged
1997 Mitsubishi Eclipse Security Information
Constant 12V+White Ignition Switch Harness
StarterBLACK/ Red Ignition Switch Harness
IgnitionBLACK/ White Ignition Switch Harness
Ignition 2Blue Ignition Switch Harness
AccessoryBlue/Black Ignition Switch Harness
TachBLACK/ Blue Or Blue/Black Coil Pack 2 Cylinder Setting
Neutral Safety WireBLACK/ White (-) PCM behind Center Console
Brake SwitchGreen Brake Switch
Trunk PinRED / Green Driver's Running Board
Parking LightsGREEN / WHITE (+) Driver's Kick Panel or Fuse Panel
Head LampRed (-) Light Switch
Factory DisarmRED / Green (-) ECU Passenger's Kick Panel
Door TriggerRED / Green (-) Courtesy Light or Driver's Kick Panel
Door LockBrown (-) Behind Fuse Panel or 20 Pin Connector High Driver's Kick Panel
Door UnlockBROWN / White (-)
Driver's LockBlue/Black Driver's Kick Panel
Driver's UnlockBlue/Red Driver's Kick Panel
Passenger UnlockBlue/Red Passenger's Kick Panel
Horn WireGREEN/ Red (-) Steering Column
Windows UpLF=GREEN/ Red, RF=BROWN / Yellow
Windows DownLF=GREEN/ Black, RF=GREEN/ YELLOW
mitsushocker
Member - Posts: 17
Posted: January 28, 2005 at 9:37 PM / IP Logged
nevermind i found, closed, ty 97 eclipse wiring diagram -- posted image.
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
