illumination wire
trollman200
Member - Posts: 17
Posted: January 30, 2005 at 8:33 PM / IP Logged
i know this may sound like a stpid question, but there are no stupid questions, just stupid people, neways, what is the orange illummination wire does on an aftermarket radio?
bullman96
Silver - Posts: 294
Posted: January 30, 2005 at 8:36 PM / IP Logged
adjusts the brightness of the deck display i assume. it goes with your dashboard adjustment switch. never used one so im not positive
leedub
Member - Posts: 25
Posted: January 30, 2005 at 10:06 PM / IP Logged
I think it work like this: It dims your display on your radio when you turn your headlights on at night and gets brighter when you turn your lights off, just like a factory radio.
wheelerdr
Copper - Posts: 337
Posted: January 30, 2005 at 11:36 PM / IP Logged
some after market decks have a illumination adjustment, yes this wire alows your display to dim when your light turn on but you can adjust the display with your illumination settings on the deck, some decks will not alow you to use this feature without the wire connected but only on a few. most will work without it.
auex
Platinum - Posts: 5,041
Posted: January 30, 2005 at 11:38 PM / IP Logged
Technically all it does is dim the lights on the deck, some have adjustments (always make sure it goes to the illumination and NOT the dimmer). It is one of those wires I don't hook up personally.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
