2004 Ford F-150 Alarm/Remote Start Wiring
kram
Member - Posts: 9
Posted: January 31, 2005 at 5:05 PM / IP Logged
new a wiring diagram for a 2004 f150. wanting to install a alarm.
thanks
mo12v
Posted: February 01, 2005 at 8:48 AM / IP Logged
Constant 12 voltsGREEN/ VIOLETIGNITION SWITCH HARNESS
Ignition 12 voltsBLUE/GREENIGNITION SWITCH HARNESS
StarterRED / BLUEIGNITION SWITCH HARNESS
Dome LightBLACK/ BLUE (+)DRIVER KICK PANEL
Trunk Pin SwitchNONE
Parking LampBROWN (+)HEADLIGHT SWITCH
Power LockPINK / YELLOWDRIVER KICK PANEL
Power UnlockPINK/GREENDRIVER KICK PANEL
Negative Pulse Door Lock Circuit
Accessories
Window UpD\ TAN/BLU P\ TAN/BLU D\ YEL/BLU P\ RED / BLK AT MAIN SWITCH
Window DownF/ WHT BLK F/ WHT/YEL R/ GRY/ORG R/ YEL/BLK  *
Ign Key WarnBLACK/ PINK (-)6 PIN CONN RIGHT OF STEERING COLUMN
Trunk ReleaseNONE
OEM HornBLUE (-)6 PIN CONN RIGHT OF STEERING COLUMN
HeadlightsRED / YELLOW (+)HEADLIGHT SWITCH
OEM Alarm ArmARMS WITH LOCK
OEM Alarm DisarmDISARMS WITH UNLOCK
* Rear Sliding Window - RED / YELLOW = Close, YELLOW/BLUE = Open At Switch
Reversal Rest At Ground Window Circuit
Remote Start
Tach SignalNOT RED / LT GREENAT ANY COIL (COIL ON PLUG)
Ignition #2BLACK/ LT GREENIGNITION SWITCH HARNESS
Ignition #3
Accessory
Neutral SafetyNON GROUNDING TYPEOEM CIRCUIT OPENS STARTER CIRCUIT
Brake LightGREEN (+)AT BRAKE PEDAL SWITCH
Reverse LightBLACK/ PINK (+)66 PIN CONN IN DRIVER KICK PANEL
Rear Window DefrostBLUE/ORANGE (-)REAR DEFROST SWITCH
 Immobilizer Bypass Circuit Diagram.
Data Buss Bypass Module Availible.
MO
Friday, August 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
