05 Honda Pilot VSS connection needed
LarryB123
Posted: February 03, 2005 at 1:22 PM / IP Logged
I need some help with making a VSS connection for my new Alpine Nav system. I understand that there is a speed control harness that I can tap into. Can anyone tell me where this is and what it looks like? Thanks.
LarryB123
Cali_pilot
Copper - Posts: 73
Posted: April 12, 2005 at 5:50 AM / IP Logged
I don't know if you still need this info but on my 03 i took the instrument cluster apart and it was the blue/white wire on the middle harness.  All you do is take two screws off on the top, pull off the black trim, and you will see that you need to take off 4 screws to get the cluster off.  Once you pull it out you will notice that there are 3 green harnesses connected to the cluster.  Disconnect all three and find the blue/white wire on the middle harness.  I'm not sure if honda changed anything on the 05 but I know the 04 has it in the same location.  You should check out HondaPilot.org, you will find lots of resolutions and answers to most of your problems.  We're always looking for new members!
2011 Ford F-150 Super-Crew FX4
HU: Pioneer AVIC-Z1
Fronts: Infinity Kappa 682.9cf
Rears: Infinity Kappa 682.9cf
Amp: Profile AP1040
Sub: Pioneer TS-SWX251
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
