Rattler 369D Problems
devile
Member - Posts: 45
Posted: February 04, 2005 at 3:53 PM / IP Logged
Ok i have everything installed correctly (i hope) i tripple checked everything. The only things i didn't do to test, is i just grounded out the hood pin, and the neutral safety switch as well as the ground to test it. Anyways, here's my problems. The brain will talk to me using the LED, but when i hit the lock/unlock button, all i here is the relay clicking, and the interior lights will comone on when (i assume) the unlock trigger is hit. But there is not action at the locks. And when i go to start it, nothing happens. NOTHING AT ALL. i push the button a million times on the remote and still nothing. WHAT"S WRONG WITH IT.
Note: for the door locks i followed the directions on this post
http://www.jeepforum.com/forum/show...&highlight=369D
PLEASE HELP!!!
__________________
1991 Jeep Cherokee Limited
stevent
Copper - Posts: 68
Posted: February 04, 2005 at 4:58 PM / IP Logged
Do not ground the hood pin. When the hood pin wire sees ground it deactivates the remote start.
devile
Member - Posts: 45
Posted: February 04, 2005 at 5:07 PM / IP Logged
OK, i'll test the remote start tomorrow, like that then. Can i ground the neutral safety to start? And what about the door locks?
auex
Platinum - Posts: 5,041
Posted: February 04, 2005 at 5:11 PM / IP Logged
If the vehicle doesn't start in anything other then park and nuetral then just ground the nuetral safety wire.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
devile
Member - Posts: 45
Posted: February 04, 2005 at 5:14 PM / IP Logged
well when i gournd it it won't start in park so maybe i should put the constant to it???
circus boy
Copper - Posts: 49
Posted: February 04, 2005 at 6:37 PM / IP Logged
did you program tach? and the nuetrul safty switch is fine grounded, as for the lock arent they five wire door locks?
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
