97 chevy cavalier remote start
d4productions
Posted: February 05, 2005 at 2:49 AM / IP Logged
I'm installing a remote start and I can't find the Tach wire
vitalio
Member - Posts: 8
Posted: February 05, 2005 at 4:46 AM / IP Logged
Chevrolet
Cavalier
1996-1999
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition #1:
PINK
Ignition #2:
WHITE
Ignition #3:
N/A
Accessory:
ORANGE
Brake Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
WHITE
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
D BLUE (LO)
(-) AT HEADLIGHT SWITCH
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is WHITE At PCM. ** This vehicle is equipped with GM's PASSLOCK Anti-Theft system. See Note #113 - General Motors PASSLOCK Bypass Diagram.
sparkie
Platinum - Posts: 2,061
Posted: February 05, 2005 at 9:41 AM / IP Logged
There is a harness in the engine bay that runs over the transmission on the driver's side of the car. The harness runs towards the firewall and is covered in split loom. There is one white wire in the harness. This is the tach wire.
sparky
Sunday, March 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
