Grounding RCA's
fastone
Copper - Posts: 83
Posted: February 07, 2005 at 12:46 PM / IP Logged
When using RCA's with a ground, or shield as I would call it, would you connect one end of the ground or both? In using shielded twisted pair wire in analog signal applications most manufacturers recommend grounding one end, at the source. Grounding both ends can create a ground loop.
bullman96
Silver - Posts: 294
Posted: February 07, 2005 at 2:38 PM / IP Logged
if you ground the deck in the same spot as the amps, i would do both ends.  other than that, i see no point in doing one end
Pioneer PEH-9660mp
Mb Quart PCE-216 biamped
JL 12W6v2
Sony XM-4026 amp for tweeters
Kenwood KAC-7251 amp for mids
JL-4100 amp for sub
fastone
Copper - Posts: 83
Posted: February 07, 2005 at 4:40 PM / IP Logged
The way it has been explained to me by engineers is that the shield acts as a drain to induced current from outside sources. If both ends are connected then you have a complete circuit, hence the term "ground loop".
DYohn
Platinum - Posts: 10,741
Posted: February 07, 2005 at 5:08 PM / IP Logged
You are correct.  I recomend grounding a shield wire at the amplifier end as this is usually easier, and leaving it disconnected at the source end.  Unless you have significant EMI/RFI problems, there is usually not much need for seperatly shielded signal cables in a car...
