Superduty Clutch bypass
carolinadiesel
Member - Posts: 6
Posted: February 08, 2005 at 4:52 PM / IP Logged
I just installed a keyless/remote start on my 99 F-250 PSD. The last thing I need to complete the job is for someone to tell me how to bypass the clutch so the remote start will work. I have search the fourums with no luck on issue. Thanks for the help
dare_ds69
Silver - Posts: 419
Posted: February 08, 2005 at 5:43 PM / IP Logged
what kind of remote start are you using?
how own your mind, control your life.
MECP certified. always use a DMM
forbidden
Platinum - Posts: 5,354
Posted: February 08, 2005 at 5:56 PM / IP Logged
Your clutch should be a positive switch. Meaning put the keys in and turn to on. Find the lower clutch switch, one line should be +12v and the other line should show open or ground. Attach one probe of your meter to this line, ground the other probe. Push the clutch in, the meter should show +12v on this line that was open or showing ground. If this wire goes to +12v it needs to have a line attached to it that goes to +12v under remote start. 99% of the time this wire can be found as the starter wire on the remote start.
Like was mentioned earlier, what kind of RS system is this that you are putting in and does the unit have a safety setting or reservation mode for use in a manual transmission vehicle. Failure to use a unit with this type of setting can result in the vehicle starting in gear, not a good thing and definitely not recommended.
dare_ds69
Silver - Posts: 419
Posted: February 08, 2005 at 6:42 PM / IP Logged
you have to make sure if it changes polarity when you put the key in on position. and tested as rob said. use a relay
carolinadiesel
Member - Posts: 6
Posted: February 08, 2005 at 8:12 PM / IP Logged
Sorry for the delay. Its an ultrastart
carolinadiesel
Member - Posts: 6
Posted: February 08, 2005 at 8:14 PM / IP Logged
And to add to that, it has a safety feature/mode, as well as an auto reservation mode. The unit is manual specific.
dare_ds69
Silver - Posts: 419
Posted: February 10, 2005 at 6:23 AM / IP Logged
try to found a wire that sends negative a soon the remote starts begings, and use a relay to by pass the clutch.Superduty Clutch bypass -- posted image.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
