2004 Isuzu Axiom Headunit and Climate
ink_driven
Member - Posts: 8
Posted: February 11, 2005 at 4:16 PM / IP Logged
I just got a 2004 Isuzu Axiom last weekend I want to install my head unit.  The problem is that the Climate controls are built into the same chasis as the radio and they both share a Heads up display on the dash.  What are my option for upgrading my head unit?  Is there a stand alone unit for digital climate control available somewhere?  If anyone has run into this situation before I would appriciate it if you could give me some suggestions or point me in the right direction.
Chris
customsuburb
Gold - Posts: 1,813
Posted: February 11, 2005 at 10:32 PM / IP Logged
You are probobly stuck with the factory radio until someone comes out with a kit. The only other options I can think of to do would be to mount the aftermarket radio in any pockets below the radio or in a center console or something. Maybe something like this? http://www.crutchfieldadvisor.com/S-XJLnkWDEJxu/customcar/showcar/constanzo_fairlane.html?page=2 except in a spot closer to the driver. You could use an IR repeater if the CD player you have has a remote so you could keep it hiddne while driving and just use a steering wheel mounted remote or something. Check out www.hzemall.com also because he has done alot of custom installs.
