toyota sienna 2003
madBedex
Member - Posts: 17
Posted: February 12, 2005 at 8:27 PM / IP Logged
Hi! Guys.
Can anyone please post car wiring info.for toyota sienna 2003,i'm trying to install a remote start on it.
I don't know if a 555u module is required to by pass the system.
Your help would be so grateful.
Thanks!
madbedex
csorb
Copper - Posts: 317
Posted: February 12, 2005 at 8:42 PM / IP Logged
Toyota Sienna 2003 Remote Starter Wiring Colors and Notes
Start:
   Red (+)
Ignition switch harness
Ignition #1:
   BLACK / YELLOW (+)
Ignition switch harness*
Ignition #2:
   BLACK/ Red (+)
Accessory:
   Blue (+)
Brake Light:
   GREEN / WHITE (+)
Brake pedal switch
Tach Signal:
Purple red behind glove box (second plug from left)
Or white red at coil near firewall
Parking Lights:
   Green (+)
Bottom of the fuse box
Notes:
   *This car is equipped with a Transponder Anti-Theft security system.
Toyota
Sienna
2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE/ Red & WHITE/ Blue (+)
OEM Alarm Disarm:
   Disarms with unlock
Dome Lights/Superv:
   RED / Black (-)
Right side of the fuse box
OEM Horn:
   GREEN/ Black (-)
Steering column harness
Power Lock:
   Blue/White (-)
Passenger kick panel**
Power Unlock:
   Blue / YELLOW (-)
Trunk Release:
   N/A
Alarm Input Wire:
   RED / Black (-)
Notes:
**These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door itself. See Note #201 Negative Trigger Door Locks
csorb
Copper - Posts: 317
Posted: February 12, 2005 at 8:47 PM / IP Logged
And yes you need the 555U. Actually it would be easier if you would just wrap some thin stranded wire around the key, Put it through a relay (87a and 30) and then 5 or 6 times around the key cylinder. Connect the relay coil to turn on with ground when running on the remote starter. Works every time especially on Siennas and you save a couple of bucks.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
