What diode size?
exsodius
Member - Posts: 34
Posted: February 15, 2005 at 3:12 AM / IP Logged
I have a 2002 ford focus. I have just installed a remote system for my central locking. I connected it to the turning indicators(flashing lights) with two 4001 diodes. But they got so warm that smoke developed. The remote modul turns the turning indicators on for 15 seconds when unlocking.
So, how much ampere do you think the turning inicators use. Totally 6 light bulbs. What diode should i use?
boomer_106
Silver - Posts: 710
Posted: February 15, 2005 at 10:38 PM / IP Logged
It might help if you give the make and model of the remote system you used. I suspect you need to use a relay to flash the light circuit. Have a look at this page.    https://www.the12volt.com/relays/page4.asp#lf1
exsodius
Member - Posts: 34
Posted: February 15, 2005 at 11:24 PM / IP Logged
[QUOTE=boomer_106]It might help if you give the make and model of the remote system you used. I suspect you need to use a relay to flash the light circuit. Have a look at this page.    https://www.the12volt.com/relays/page4.asp#lf1[/QUOTE]
The car is 2002 ford focus wagon.
Remote system is Seco-larm SLI830 keyless entry
boomer_106
Silver - Posts: 710
Posted: February 16, 2005 at 8:22 PM / IP Logged
Looking up the specs on that unit it says it has a built in light flashing relay so that's good. Did the install manual tell you to put these diodes on?
exsodius
Member - Posts: 34
Posted: February 16, 2005 at 8:37 PM / IP Logged
boomer_106
No the install manual do not tell me to put on diodes.
But i have connected it to the direction signals. And thats is a left and rigth circuit. So if i connect them toghether, then both turning signals will get light. And then other cars wont know which way i am going :) But that could be kinda cool.
boomer_106
Silver - Posts: 710
Posted: February 16, 2005 at 8:42 PM / IP Logged
You should have it connected to the parking light circuit. You would find that at your light switch. The diagram I see says its Orange with a black stripe. Use your meter to verify that when you get to it. Its a positive circuit. You don't need diodes. Connect like this and you should be in business.
exsodius
Member - Posts: 34
Posted: February 16, 2005 at 8:45 PM / IP Logged
Does this diagram say where this ORANGE / black wire is located?
Where did you find the diagram?
boomer_106
Silver - Posts: 710
Posted: February 16, 2005 at 8:48 PM / IP Logged
Here is the diagram and yes it says it's located at the light switch.
Ford
Focus
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GRAY/BLACK
IGNITION SWITCH HARNESS
Ignition  #1:
GREEN/ YELLOW
IGNITION SWTICH HARNESS*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
YELLOW
Brake  Light:
GREEN/ RED (+)
AT SWITCH ABOVE PEDAL **
Tach  Signal:
BLACK/ LT. GREEN
AT COIL MODULE
Parking Lights:
ORANGE / YELLOW (+)
AT LIGHT SWITCH
Headlights:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With Ford's Passive Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** This Wire Is Only Active When The Ignition Is On.
Ford
Focus
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
OEM Alarm Disarm:
BLUE/LIGHT GREEN
IN DRIVERS KICK PANEL
Dome  Lights/Superv:
OEM Horn:
Power  Lock:
BLACK/ RED (-)
DRIVER'S KICK IN DOOR BOOT ***
Power  Unlock:
BLACK / YELLOW (-)
Trunk  Release:
BLACK / YELLOW (-)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
Notes:
*** See Installation Note # 201 - Negative Pulse Door Lock Diagram.
boomer_106
Silver - Posts: 710
Posted: February 16, 2005 at 8:50 PM / IP Logged
Sorry I meant Orange / YELLOW
exsodius
Member - Posts: 34
Posted: February 16, 2005 at 8:53 PM / IP Logged
Wow where did you get this?
But parking lights says orange / YELLOW not orange with black stripe as your previous post?
