99 Alero security Install
Schimmel03
Member - Posts: 8
Posted: February 17, 2005 at 11:26 PM / IP Logged
I found the wiring diagram for the Alero, but I'm having trouble figuring this part out:
*2 Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.
What does this mean? I figured out how to lock the car but not unlock. Can someone help me out with this? Thanks!
Eric
KarTuneMan
Platinum - Posts: 7,056
Posted: February 18, 2005 at 2:11 AM / IP Logged
Relay #1  pin 85 neg LOCK  trigger from alrm
pin 86 a fused 12 volts
pin 87 ground
pin 30 output to the one wire lock
Relay#2 is set up  the same  pin 85 gets neg unlock trigger from alarm.   pin 87  gets grounded.  pin 30 put in line a 1500 ohm resistor, then take pin 30 to the onewire door lock
Schimmel03
Member - Posts: 8
Posted: February 18, 2005 at 9:54 AM / IP Logged
Thanks! I'll try that and see how it works!
