thumping sound from subs
supradude
Silver - Posts: 915
Posted: February 18, 2005 at 10:22 AM / IP Logged
I have stumbled across the weirdest problem with my subs. They have started making a thumping sound when I turn on the HU. Not a turn-on thump. After the amp powers up, they will make this sound several times and then stop doing it. I have tried replacing the fuses, checking all the connections on the amp, checking the ground. Since both amps turn on with the same wire, I have elimanated the HU as the problem. Only the bass amp is doing this. Could it be something inside the amp going bad? I've never ran into this problem before.
'85 Toy
DYohn
Platinum - Posts: 10,741
Posted: February 18, 2005 at 10:25 AM / IP Logged
Could be a level mismatch in your gains, or a bad ground (or a ground that has changed or corroded) or a damaged RCA input, or yes a sign of early amplifier failure.  Take the amp out and have it bench tested.
bbattleson
Member - Posts: 7
Posted: February 18, 2005 at 5:08 PM / IP Logged
Are both amps grounded at the same point?
supradude
Silver - Posts: 915
Posted: February 18, 2005 at 10:21 PM / IP Logged
Yes, both are.
'85 Toy
supradude
Silver - Posts: 915
Posted: February 19, 2005 at 1:01 PM / IP Logged
I have still been looking with no luck. Could it be one of the subs? I am going to replace the amp and see if it is the problem.
'85 Toy
DYohn
Posted: February 19, 2005 at 1:06 PM / IP Logged
Like I said, pull the amp, take it to a shop, pay them $20 to have it bench tested.
Dutton
Member - Posts: 15
Posted: February 20, 2005 at 1:31 AM / IP Logged
I had this problem occur when I had two 15's in an eagle talon 2 years ago, the shop I went to said my head unit was not putting enough volts out of the rca output.  They sold me an electronic equalizer and everything worked perfect.  They said this happens often when the amps gain is turned up and the preamp output is not very strong.  Just a suggestion, this may or may not be the same exact problem you are running into.
supradude
Silver - Posts: 915
Posted: March 01, 2005 at 7:41 PM / IP Logged
Just to update my problem : Seems it was my amp. The shop can't actually find the problem, but I hooked up an old Orion 225HCCA that I had sitting around while they were checking the Crossfire amp and the "thumping sounds" I was getting went away. Thanks for all the info 12volter's.
'85 Toy
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
