2000 Camry Tach Wire
illmattix
Member - Posts: 31
Posted: February 19, 2005 at 11:38 AM / IP Logged
Just wondering if anyone knows exactly where the tach wire is on a 2000 Camry. The sheet says Black(AC) or Yellow/Red Ignition Driver's Side. I can't find that color. Is it under the hood or inside the car???
KarTuneMan
Platinum - Posts: 7,056
Posted: February 19, 2005 at 11:58 AM / IP Logged
Black and orange @ the ECM behind the glove box , OR under the hood.  On the four banger,  its on the end of the drivers side valve cover in a whitish grayish plug with 4 wires stickin out of it. Use the black one.
On the 6 cylinder, go to the coil on the DRIVERS side,and use the yellow/red
illmattix
Member - Posts: 31
Posted: February 19, 2005 at 1:44 PM / IP Logged
Thanks Guys.
illmattix
Member - Posts: 31
Posted: February 19, 2005 at 4:15 PM / IP Logged
Alright, I can't seem to find anything yellow/red at the left shock tower or anywhere on the driver's side under the hood for that matter. I'm also having another problem. I'm getting the starter relay to engage when i try to remote start but the car won't start. Is there some kind of security thing that i need to buy a bypass for???
thepencil
Gold - Posts: 1,526
Posted: February 20, 2005 at 7:44 AM / IP Logged
Tach signal has to be learned first!
Be careful whose advice you buy, but be patient with those who supply it.2000 Camry Tach Wire - Last Post -- posted image.
johnnyb1231
Member - Posts: 34
Posted: February 20, 2005 at 9:25 AM / IP Logged
on just about every car i do i use the "uncommon colored" wire off of one of the coils or fuel injectors... on most toyotas however i usually just drop the glove box and pull it off the ecm
dont know if this will be any help but just some food for thought
10nesne1
Silver - Posts: 284
Posted: February 20, 2005 at 10:11 AM / IP Logged
Here is the info. Good luck
TACH BLACK OR GRAY (-)   SEE NOTES*
* 4 CYLINDER MOTOR USE THE BLACK WIRE IN THE GRAY PLUG AT THE COIL ON THE DRIVERS SIDE OF THE MOTOR 6 CYLINDER MOTOR USE THE GRAY WIRE LOCATED AT THE IGNITOR ON A BRACKET JUST IN FRONT OF THE STRUT TOWER. THE MODULE SAYS DENSO ON IT
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
