1999 Pontiac Sunfire Alarm & Remote Start
Rousseau_s909
Posted: February 21, 2005 at 10:50 PM / IP Logged
I am installting a remote start and alarm into a 1999 pontiac sunfire. Can anyone help me with all the info from Directech. Like the wiring and where it is all at. Also step by step on instillation of alarm & remote start.
boomer_106
Silver - Posts: 710
Posted: February 21, 2005 at 11:01 PM / IP Logged
Here is a diagram for that car. As far as step by step your manual should tell you that stuff. If you have questions come back and ask. There are people here willing to help.
Pontiac
Sunfire
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
ORANGE
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
BLUE (LO) & PINK (HI)
(+) AT HEADLIGHT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * 2.4L Engine Tach Wire Is WHITE At Powertrain Control Module (PCM). 2.2L Engine Tach Wire Is BLUE/WHITE At PCM. PCM On Both Located In Passenger Front Fender. ** This vehicle is equipped with GM's PASSLOCK Anti-Theft system. See Note #113 - General Motors PASSLOCK Bypass Diagram.
Pontiac
Sunfire
1996-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
OEM Alarm Disarm:
N/A
IN SCHEMATICS
Dome  Lights/Superv:
LT GRN/BLK & L BLUE (-)
AT CONVENIENCE CENTER MODULE ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
L BLUE
EITHER KICK W/O OEM KEYLESS
Power  Unlock:
WHITE
PANEL WITH OEM KEYLESS ****
Trunk  Release:
BLACK/ WHITE (+)
AT OEM KEYLESS MODULE IN TRUNK
Alarm  Input Wire:
Notes:
*** Lt. GREEN/ BLACK (-) Covers Driver Door Only, L BLUE (-) Covers All Other Doors, Diode Isolation Needed Cathode (Band) Side Of Diode Faces Oem Wires. Conv. Center Module Located Behind Driver Dash To Left Of Steering Column. **** Without OEM Keyless, See Note # 203 - Reverse Polarity Door Lock Diagram. With OEM Keyless, See Note #202 - Positive Pulse Door Lock Diagram.
johnnyb1231
Member - Posts: 34
Posted: February 22, 2005 at 12:55 AM / IP Logged
you need a 555L from dei... for your bypass
johnnyb1231
Member - Posts: 34
Posted: February 22, 2005 at 12:59 AM / IP Logged
and to clarify the keyless notes...
Power Lock lt. blue    either kick panel
Notes: Non keyless cars, locks are 5wi (type C) and they are mastered from the passenger side switch. Keyless cars, locks are positive trigger (type A).
Power Unlock white    either kick panel
cutter1122
Copper - Posts: 103
Posted: February 23, 2005 at 8:17 PM / IP Logged
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
