Switching Batteries/series to parallel
jjkeen
Posted: February 23, 2005 at 2:58 PM / IP Logged
I have 2-6volt batteries that need to run parallel 6 volt and be triggered to run 12v series. Does any one know of a way to wire relays to acheive this output.  At rest the batteries need to show 6v and when triggered the batteries need to show 12v. (parallel / series)  thanks in advance.  Jason
Jkeen
the1alchemist
Copper - Posts: 65
Posted: February 23, 2005 at 8:56 PM / IP Logged
need some more info...
a couple bosch relays won't work for a high current situation ..but overkill for a couple cell phone batteries ..
what's the story..?
I love a challenge but .. psychiccryptography isn't my thing...
'Stereo' Mike
The Audio CARtist,LLC
9600 Balt. Ave.
College Park,MD 20740
301-474-6260
jjkeen
Posted: February 24, 2005 at 10:43 AM / IP Logged
Thanks, for the reply,
The batteries I am trying to wire series/parallel are 2 pairs of 6v 12ah Unsure of the current or draw on the circuit.
This is for a "turbo boost" button on my daughter's powerwheels quad runner.  the quad is designed to run 12v but i have succesfully ran her quad with 24v w/o problem,  I tend to overkill wiring and connectors so i think that has helped.
At 24v the quad runs in the 10-12 mph and is a lot more fun for her.
She just cannot controll the quad and manuver it at slow speeds due to the ON/OFF switch, there is no variable.
The reason I want to wire seris/parallel is so when she is off the "turbo" then the quad will draw 12v from all the batteries the same, but when the button is pushed then 24v is switched  with the same batteries. (draw from all the batteries the same again)
Hope this helps explain a bit more.
PS. I have basic wiring skills and can figure out schematics and wiring diagrams pretty well.
Jason
Jkeen
ravenndude
Silver - Posts: 250
Posted: February 24, 2005 at 1:11 PM / IP Logged
I would thinkt hat this would work for you, Just put batteries in instead of voice coils
Switching Batteries/series to parallel -- posted image.
jjkeen
Posted: February 24, 2005 at 1:20 PM / IP Logged
Thanks that's what I was looking for.  I'll let you know how it goes.  Jason
Jkeen
