2004 BMW 530I info?
FinalFrontier
Member - Posts: 12
Posted: February 26, 2005 at 11:54 PM / IP Logged
Anyone have wiring specs or info on adding an aftermarket amp to an 2004 BMW 530I? Im sure it has an factory amp located somewhere. It has the radio with the knob in the center console that controls everything. I want to upgrade the amp and speakers in one. Also need speakers sizes if anyone has them.It has the 6 speaker system.
tcss
Silver - Posts: 1,623
Posted: February 27, 2005 at 4:04 PM / IP Logged
Look into JLs new " clean sweep " OEM adapter. Gives you 4 flat RCA outputs from any OEM stereo. I believe this system is internally equalized, so if you are keeping the factory HU, this might be the only way around it.
FinalFrontier
Member - Posts: 12
Posted: February 27, 2005 at 8:02 PM / IP Logged
that would be nice! But im just looking to see if anyone knows where to tap onto the factory wiring or where the factory amp is located.And also if anyone know the wire colors for the speakers.
