2004 Ford F-150 Radio Wiring 24-16-8 Pin
fkmaconi
Posted: March 03, 2005 at 6:35 AM / IP Logged
I have the (new body style) 2004 f150 6 in dash cd player w/audiophile. I need to know what the wiring is for the 24-16-8 pin adapters.
Thanks in advance
ss-installer
Silver - Posts: 444
Posted: March 03, 2005 at 7:03 AM / IP Logged
the adapter is color coded with any aftermarket deck.
yellow-12v
red-acc
black-ground
blue-amp or ant
grey,white,green,purple-speaker leads
fkmaconi
Posted: March 03, 2005 at 7:13 AM / IP Logged
I'm looking for the stock adapter wiring information. I have 48 wires. I need to make sense of what I have. This is far from aftermarket.
fkmaconi
Posted: March 03, 2005 at 7:23 AM / IP Logged
There is a 24 pin adapter,16 pin adapter and a 8 pin adapter going into the back of the radio. The wiring leading into the adapters is what a need the information on. I am installing a xm system and I need to know what wire to tie into for ACC. I would like the xm to shut down with the radio when the doors open. The radio does that now.
Ween
Platinum - Posts: 1,368
Posted: March 03, 2005 at 7:37 AM / IP Logged
this may help
2004 Ford F-150 Radio Wiring 24-16-8 Pin -- posted image.
fkmaconi
Posted: March 03, 2005 at 9:30 PM / IP Logged
Thanks............The colors for the new f150 are different but it was still the same pin. GREEN/ YELLOW stripe. Acc delay. Thanks again
Iccarus72
Posted: March 12, 2005 at 2:30 PM / IP Logged
Do you have the pinouts for the 16 pin and/or the 8 pin connectors?
Ween
Posted: March 12, 2005 at 3:33 PM / IP Logged
2004 Ford Expedition OEM Overhead Plug PinOut - Found @ Rear Of OEM Radio
Ween
Posted: March 12, 2005 at 3:34 PM / IP Logged
2004 Ford Expedition OEM Subwoofer Plug PinOut - Found @ Rear Of OEM Radio
Iccarus72
Posted: March 13, 2005 at 11:09 AM / IP Logged
Does anyone know what the Audio corporate Protocal A and B are used for from the 16 pin connection?  I was wondering if I would be able to use the DVD Player left & rights, the shield and the Audio System On to run my iPod through the system.  My only concern is whether you have to send some kind of signal through the two corporate protocol wires.
Any thoughts/help would be greatly appreciated.
Thanks!
Sunday, March 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
