2002 Escalade EXT Navigation
danielbarth
Posted: March 08, 2005 at 5:56 PM / IP Logged
I want to put the new touchscreen navigation from an '05 Escalade in my '02 EXT. I have the Bose system with the 6-disc changer and On-Star, but it doesn't have navigation. What do I need (other than the '05 head-unit) to make this work? I heard that I have to replace the A/C controls with the new ones to make it all fit. Any input would be extremely helpful.
Ickster40
Member - Posts: 32
Posted: March 08, 2005 at 10:35 PM / IP Logged
good luck! it's not worth the headache, there different amps, and harness, you need a new dah bezel for the double din opening. I wouldn't advise it.
DJ,Scottsdale Extreme Sound
Ickster40
Member - Posts: 32
good luck! it's not worth the headache, there different amps, and harness, you need a new dash bezel for the double din opening. I wouldn't advise it.
oonikfraleyoo
Gold - Posts: 1,069
Posted: March 08, 2005 at 11:41 PM / IP Logged
You would be better off building a carputer. Same amount of work and might even be cheaper.
Nik
Jeeputer Progress
[|||||||||||-] 90%
Check it out.
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
