1992 S-10 chevy
Ed jr
Posted: November 06, 2002 at 9:38 AM / IP Logged
       wire diagram for security chip under the dash,
   need to disconnect or bypass.
ed jr
Moderator - Posts: 12,488
Posted: November 06, 2002 at 2:44 PM / IP Logged
No chip in this vehicle. Here is the wiring for it:
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow or purple    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |5wi|drivers kick panel          |
|     POWER UNLOCK|BLACK/ white         |5wi|drivers kick panel          |
| PARKING LIGHTS +|brown               |   |switch or rear harness      |
|       HEADLIGHTS|yellow              |+  |at switch                   |
|     DOOR TRIGGER|white               |-  |pin or courtesy light       |
| DOME SUPERVISION|use door trigger    |   |                            |
|       TACHOMETER|white               |   |coil on top of engine       |
|       BRAKE WIRE|white               |+  |at brake pedal switch       |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |L of steering column        |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/wht - tan       |A  |drivers door harness        |
Notes:
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
