blue led scanner
accord78
Copper - Posts: 97
Posted: March 12, 2005 at 6:23 PM / IP Logged
i just installed 2 530t's on a clifford and i was wondering should i diode the blue scanner to the ground when armed output from the alarm beacuse i already have 2 window modules hooked up to it????
daniel2002p
Silver - Posts: 524
Posted: March 12, 2005 at 8:09 PM / IP Logged
you can never go wrong by putting a diode in some place as long as it was put in right.  I say go for it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
bretbowman
Copper - Posts: 156
Posted: March 14, 2005 at 2:15 AM / IP Logged
I 2nd that.  It will never hurt and can save you HOURS of troubleshooting later on if you were to have a problem because of that connection and perhaps didn't know right away that it was that connection that was giving you problems.
2002 Toyota Sequoia Limited 2WD (Clifford G5 Avantguard 5 w/ 2 SmartWindows modules) - IT Engineer - NRA Life Member - LDS Return Missionary - Married for time AND ETERNITY - Eternally sealed family
