key in ignition alarm 2005 Ford Ranger
raykl
Posted: March 13, 2005 at 11:02 AM / IP Logged
How do I disable the annoying key-in-ignition-when-the-door-is-open alarm in my 2005 Ford Ranger? Does anyone have the wiring for this vehicle yet?
I'm usually pretty adventurous in fiddling with auto wiring but this truck has an air bag. It's kind of like a loaded gun pointed at my head. I don't want to inadvertently set it off.
Thanks in advance - Ray
P.S. Please excuse me if this post is revieved twice. My phone line went dead when I tried to send it the first time.
boomer_106
Silver - Posts: 710
Posted: March 14, 2005 at 11:41 AM / IP Logged
Keysense is BLACK/ Pink in the ignition harness.
dare_ds69
Silver - Posts: 419
Posted: March 14, 2005 at 5:50 PM / IP Logged
12volts yellow (x3)(common 40A)  +  ignition harness
Starter RED / lt. blue  +  ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense BLACK/ pink  -  ignition harness
Power Lock pink / YELLOW  -  SJB, large black plug, pin 5
Notes: The SJB (Smart Junction Box) is the fuse/relay box in the passenger kick panel.
Power Unlock pink/lt. green  -  SJB, large black plug, pin 9
The SJB in this vehicle shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1093.
Lock Motor red  5wi SJB, gray plug, pin 9
Unlock Motor lt. blue  5wi SJB, large black plug, pin 7
Parking Lights+ brown  +  SJB, brown plug, pin 8
Parking Lights- WHITE/ black  -  switch or SJB, sml blk plug, pin 16
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +  turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +  turn signal switch
Reverse Light BLACK/ pink  +  driver kick, harness to rear
Door Trigger yellow/black (D), gray/red (P) -  SJB
Notes: The driver door trigger is yellow/black in the large black plug, pin 6. The passenger door(s) trigger is gray/red in the small black plug, pin 3. Use both wires and diode isolate each from each other and the control module. Refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ lt. blue  +  SJB, gray plug, pin 14
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer tan / YELLOW  ac  PCM, pin 48
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall, under the hood.
For tach, can also go to the ignition coil pack or any fuel injector and use the wire that is NOT red.
Wait to start N/A
Brake Wire lt. green  +  brake pedal switch
Parking Brake RED / yellow  -  switch or SJB, lrg blk plug, pin 17
Horn Trigger yellow/lt. green to dk. blue  -  switch or SJB, sml blk plug, pin 18
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
key in ignition alarm 2005 Ford Ranger -- posted image.
Immobilizer Bypass Module:Required: YesType: SecuriLockPart #: 556S, 556U, or 555U
how own your mind, control your life.
MECP certified. always use a DMM
