R/S Double Pulse
tampa77
Copper - Posts: 65
Posted: March 14, 2005 at 4:12 PM / IP Logged
Good Afternoon,
I am working on avehicle with an older DEI R/S. I have no remote or instructions for the R/S, I am unsure of whether this can be achived, but here it goes.
How can you have the unit activate by double pulse rather than single pulse? If I use a latching relay it will activate every second time the factory key fob lock or unlock button is pressed.  If you put a (+) to it it activates, but I need to have it on a double pulse like the higher end models do, but only if a double pulse is done within 10 seconds?
I may be reaching but it may be easier than ripping the old unit out and buying and putting a new one in. Any suggestions appreaciated, otherwise off to CC I go.
        John
dare_ds69
Silver - Posts: 419
Posted: March 14, 2005 at 5:46 PM / IP Logged
http://www.directechs.com/guides/manuals/ig/valet/N551T.pdf
try this, it may help you
how own your mind, control your life.
MECP certified. always use a DMM
tampa77
Copper - Posts: 65
Posted: March 14, 2005 at 6:32 PM / IP Logged
No good. I am unable to get a model # and I have no remotes anyway (for programming).
   Thanks though,
 John
swamprat323
Gold - Posts: 1,335
Posted: March 14, 2005 at 8:00 PM / IP Logged
there no model number on the unit.
tampa77
Copper - Posts: 65
Posted: March 14, 2005 at 8:20 PM / IP Logged
I believe it may be a Hornet 851, it is attached above the BCM and difficult to see. I
 did find an activation wire, however it would cost more to get the remotes and try to reprogram than buy a new one. It's a friends vehicle (Bought Used, no aftermarket key fob with it, saw the DEI R/S warning tag under hood and that's when I looked and found the unit). So I figured I could hook it up to the factory Keyless entry but need to somehow get a 2X pulse to activate it..
  John
dare_ds69
Silver - Posts: 419
Posted: March 15, 2005 at 6:00 PM / IP Logged
well i do remote start on factory key-less  for cadillacs the way that we do is the coustomer have to press 3 times lock on the remote to remote starter the car
accord78
Copper - Posts: 97
Posted: March 15, 2005 at 6:19 PM / IP Logged
sup dude get a dei 452t door lock pulse generator u can make it into a negative or positve double pulse output
tampa77
Copper - Posts: 65
Posted: March 15, 2005 at 7:05 PM / IP Logged
After reading this, I am be unclear on this to you guys (If so sorry). Since I can only input a single pulse to the remote start, I need to somehow make a double pulse turn into a single.
lock the vehicle twice and have the  (-) output  from the vehicle activate on the second pulse only to the R/S input .
I know you can easily turn a single pulse to a double, but reversed is a noodle scratcher!
At this point I just want to figure this out whether I use this R/S or not, ya know.
BTW -  what's up with CC not stocking DEI and having this CA crap? Anyone know where you can get DEI stuff besides Ebay?
  Thanks,
   John
mladams
Copper - Posts: 57
Posted: March 18, 2005 at 2:42 PM / IP Logged
yeah, circuit city. As of april we are carrying only DEI again.  My advice , be patient and wait and get DEI through CC.
Matt Adams
Electrical Engineer Major
York College of PA
Chevy Cavy Rally Sport
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
