AM Antenna in a 97 or 98 Audi A4
ecko72rhino
Posted: March 14, 2005 at 4:28 PM / IP Logged
ok,   I have a 98  Audi A4 that I am installing a aftermarket headunit into.  and I used a Metra antenna adapter for the Antenna to the headunit,   but I am not receiving any AM stations except one or two.  I also tried using Metras Amplified antenna adapter for the Audi. and it produced the same results.  Great FM and no AM.
I couple sources said that I still need to power up the cars power antenna lead.  Is this true even though the car does not have a powered antenna?
Strive for perfection
cayuga420
Member - Posts: 9
Posted: March 18, 2005 at 9:34 PM / IP Logged
yes this it true.
Stilly
Posted: March 21, 2005 at 3:35 AM / IP Logged
Ditto, The Audi has its antenna in the rear windscreen(looks like demister strips) and an  active antenna booster in the c pillar from memory and requires powering up to pass any AM signal. Wire up the auto antenna circuit and AM will appear!
eckorhino
Posted: March 25, 2005 at 12:42 PM / IP Logged
Thanks for your help guys
The Doctor
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
