1995 Chevy Tahoe
jaurora
Silver - Posts: 429
Posted: March 15, 2005 at 8:45 AM / IP Logged
Could someone help me out with a tech sheet for this vehicle. I seen that some said it has passkeyII and some said needs module for door locks. I need a good sheet so I know what to order.
Thanks,
Jeremy
MECP certified (If it really means anything)
Jeremy
thepencil
Gold - Posts: 1,526
Posted: March 15, 2005 at 10:06 AM / IP Logged
Jeremy,
Doesn't look like you will require any of the above that you mention.
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / TAHOE / 1995 / Remote Start
12volts red    +   ignition harness
Starter yellow or purple    +   ignition harness
Second Starter
Ignition pink    +   ignition harness
Second Ignition pink/white or white    +   ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition
Accessory orange    +   ignition harness
Second Accessory
Keysense
Power Lock lt. blue      either door boot
Notes: The 4 door models are positive trigger (type A), and the 2 door models are 5-wire (type C).
Power Unlock white      either door boot
Lock Motor lt. blue      keyless entry module
Notes: The keyless entry module is located above the gas pedal.
Unlock Motor tan      keyless entry module
Parking Lights+ brown      headlight switch
Notes: Also found low in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger purple    -   headlight switch
Dome Supervision white    -   headlight switch
Trunk/Hatch Pin tied in with doors
Hood Pin
Trunk/Hatch Release black    +   release switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer PURPLE / white    AC ECM
Notes: Also found as white at the instrument cluster. For diesel tach, use white at the alternator or instrument cluster. Diesel wait to start wire is dk. blue (+) located at the instrument cluster.
The ECM is located behind the glove box to the right side.
Wait to start
Brake Wire white    +   brake pedal switch
Parking Brake
Horn Trigger black    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: No Type: N/A Part #: N/A
Notes: N/A
Be careful whose advice you buy, but be patient with those who supply it.1995 Chevy Tahoe -- posted image.
