remote lead doesn't work on radio??
dragon51081
Posted: November 06, 2002 at 8:14 PM / IP Logged
Im wondering what should I do if the remote lead doesn't work? I have an equalizer and two amps and they wont turn on. I found a remote wire connected to one of the amps was split in half. So I reconnect it and it still doesnt work. Can you tell what had happen?
Jeep Mods
Platinum - Posts: 12,488
Posted: November 06, 2002 at 8:28 PM / IP Logged
Use the power antenna lead and if you do not have one of these, use the switched ignition wire.
dragon51081
Posted: November 06, 2002 at 9:55 PM / IP Logged
Hey Jeff...What if it still doesnt turn on? I haven't tried connecting it yet, but just in case it doesnt turn on...All the fuses and connections are fine...I just want to know in case this happens..Thanks for your time...
Jeep Mods
Posted: November 07, 2002 at 8:28 AM / IP Logged
If you are a little leary about wasting time and findoing out it still doesn't turn on, what you can do is get a smal 3" piece of wire and jump the remote terminal to the 12 volt constant terminal. The amp should respond and the light should turn on as well. You can do this with the system on so that when you jump it, the amp will power the speakers that are attached to it. If it does then use the antenna lead or ignition lead as you new turn on wire.
SnomanF150
Silver - Posts: 269
Posted: November 07, 2002 at 12:57 PM / IP Logged
watch that antenna lead though.. some newer radios turn off the antenna output when you go to CD.. had one of my installers actuallly troubleshoot that in a BMW using the factory amp for an hour before he decided to ask me.. when you play the tuner, it plays fine.. put in a CD and no audio.. go figure.. turning off the amps have a tendency to do that..
George
David's Car Stereo
Baton Rouge, LA
dragon51081
Posted: November 07, 2002 at 4:43 PM / IP Logged
Hey whats up guys..I used the 12+ switch wire for my remote and its working great. I also put a switch so I can also turn it off..Thanks for all the help and advice. I really appreciate it. Thanks again and have a great day..
-Chan
Jeep Mods
Posted: November 08, 2002 at 1:29 AM / IP Logged
No problemo
