2005 Toyota Corolla remote start information
Kobaltic
Member - Posts: 36
Posted: March 16, 2005 at 6:19 AM / IP Logged
I need the remote start information for this car. Thanks in advance,
thepencil
Gold - Posts: 1,526
Posted: March 16, 2005 at 9:55 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / COROLLA / 2005 / Remote Start
[PRINT THIS PAGE]
12volts white (25A), black (15A)   +   ignition harness
Starter red   +   ignition harness
Second Starter N/A
Ignition BLACK/ white   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue/red   +   ignition harness
Second Accessory N/A
Keysense blue/black   -   ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock green   -   driver kick, 10 pin plug
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlock blue / YELLOW (double pulse)   -   driver kick, 10 pin plug
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug.
Lock Motor blue   5wi driver kick, blue 12 pin plug
Unlock Motor red   5wi driver kick, blue 12 pin plug
Parking Lights+ green   +   driver kick, harness to rear
Parking Lights- GREEN / WHITE   -   headlight switch
Hazards yellow/black   -   flasher relay left of fuse box
Turn Signal(L) GREEN/ black   +   flasher relay left of fuse box
Turn Signal(R) GREEN/ YELLOW   +   flasher relay left of fuse box
Reverse Light RED / black   +   front of fuse box, 10 pin plug
Door Trigger RED / white   -   interior light switch on dash
Dome Supervision RED / black   -   interior light switch on dash
Trunk/Hatch Pin RED / white   -   light in trunk
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black   ac   ECM, far right plug, pin 5
Notes: The ECM (Engine Control Module) is behind the glove box.
On the XRS models, the tach wire is in the second plug from the right, pin 3.
Wait to start N/A
Brake Wire GREEN / WHITE   +   brake pedal switch
Parking Brake RED / black   -   parking brake switch
Horn Trigger GREEN/ YELLOW   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U or 555U
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.2005 Toyota Corolla remote start information - Last Post -- posted image.
Kobaltic
Member - Posts: 36
Posted: March 16, 2005 at 3:01 PM / IP Logged
Thanks alot and for the quick response
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
