crimestopper cs-9704rs remote start
higgy
Posted: November 08, 2002 at 12:17 AM / IP Logged
I need info on installing this unit on 93' blazer tahoe package, do i need extra relays?? how many. also need help finding a install/owners manual for the alarm.  Thanks a lot
Platinum - Posts: 12,488
Posted: November 08, 2002 at 12:50 AM / IP Logged
http://www.crimestopper.com/techweb/ProductDiagrams/cs9704.PDF
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow or purple    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*1 |drivers kick panel          |
|     POWER UNLOCK|BLACK/ white         |*1 |drivers kick panel          |
| PARKING LIGHTS +|brown               |   |switch or rear harness      |
|       HEADLIGHTS|yellow              |+  |at switch                   |
|     DOOR TRIGGER|white               |-  |pin or courtesy light       |
| DOME SUPERVISION|use door trigger    |   |                            |
|TRNK/HTCH RELEASE|black               |+  |relay under left dash       |
|       TACHOMETER|white               |   |coil on top of engine       |
|       BRAKE WIRE|white               |+  |at brake pedal switch       |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |left of steering column     |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/wht - tan       |A  |drivers door harness        |
|  LR WINDOW UP/DN|dk. green - purple  |A  |drivers door harness        |
|  RR WINDOW UP/DN|lt. green - pur/wht |A  |drivers door harness        |
Notes:
*1 2-door vehicles are 5-wire (type C), 4-door vehicles are 3-wire positive (type A).
higgy
Posted: November 08, 2002 at 1:17 AM / IP Logged
thanks a lot bud
Posted: November 08, 2002 at 1:45 AM / IP Logged
no problemo
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
