low volume on alarm horn
83malibuRida
Member - Posts: 46
Posted: March 22, 2005 at 11:27 AM / IP Logged
I have a dei rattler and the siren isnt as loud as i would like it to be. is there a way to tie my car horn into the alarm so that it beeps when armed/disarmed and also when triggered? will I need a 5 pin relay? how do I go about hooking this up?
Nick Scott
thepencil
Gold - Posts: 1,526
Posted: March 22, 2005 at 1:24 PM / IP Logged
Trying cleaning the grounding point of your siren first. Buy a new siren, cost $10-20, a lot less work and better result.
Be careful whose advice you buy, but be patient with those who supply it.low volume on alarm horn - Last Post -- posted image.
83malibuRida
Member - Posts: 46
Posted: March 22, 2005 at 1:38 PM / IP Logged
will do. how many dB is a loud siren anyways? I still want to know how to do the car horn addition.
Nick Scott
thepencil
Gold - Posts: 1,526
Posted: March 22, 2005 at 1:44 PM / IP Logged
Run a relay and you can put as many siren as your heart desire. If your alarm unit has a horn wire you can connect that directly to the car horn wire.
dare_ds69
Silver - Posts: 419
Posted: March 22, 2005 at 6:10 PM / IP Logged
don't conected direct to the horn because the brain send 12v constat, you need to do a relay and flasher for horn
86siren wire
85ground
87positive or negative (depends in the car horn some needs positive some needs negative)
30goes to flasher and from flasher to horn wire
how own your mind, control your life.
MECP certified. always use a DMM
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
