Autopage RF-700
cantactright
Posted: March 23, 2005 at 10:56 PM / IP Logged
I have a Autopage RF-700 car alarm on a 1997 Honda Civic and I am needing the wiring diagram for it. Also, I was wanting to know if a universal keyless remote will work with it. I would appreciate it if someone could help me with this task.? Thanks for your time and help!
dare_ds69
Silver - Posts: 419
Posted: March 24, 2005 at 6:34 AM / IP Logged
here it goes
12volts white (40A)  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow  +  ignition harness
Second Accessory WHITE/ black  +  ignition harness
Keysense blue/white to blue/red  -  ignition harness
Power Lock GREEN / WHITE  -  driver kick, blue plug
Notes: Also found in the green factory alarm plug located behind the radio.
Power Unlock GREEN/ orange  -  driver kick, blue plug
Use blue / YELLOW to unlock the driver door only.
Lock Motor WHITE/ red  5wi driver kick, door harness
Unlock Motor blue/red to yellow/red  5wi pwr door lock ctrl unit in driv door
Parking Lights+ RED / black  +  driver kick, fuse box
Notes: Male blade terminal at fuse box. Also at the back of the dimmer switch.
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red  +  steering column
Turn Signal(R) GREEN/ YELLOW  +  steering column
Reverse Light GREEN/ black  +  driver kick, harness to rear
Door Trigger lt. GREEN/ red  -  factory alarm plug
Can also be found in a light green plug above the fuse box or bottom of driver kick, harness to rear.
Dome Supervision lt. GREEN/ black  -  driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black  -  driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue  ac  test tachometer connector
Notes: Driver side fire wall under hood.
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / green  -  parking brake switch
Horn Trigger blue to gray  -  steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Autopage RF-700 -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
how own your mind, control your life.
MECP certified. always use a DMM
