Flat Cuts
LeanNCut
Member - Posts: 29
Posted: March 28, 2005 at 7:11 AM / IP Logged
Hi,
What does it mean if your subs thump rythmically with the bass then suddenly they skip a beat? It almost seems as if they flatline for a second then resume. The music is still there except there's no bass response.
Thanks.
stevdart
Platinum - Posts: 5,816
Posted: March 28, 2005 at 7:59 AM / IP Logged
If it's not in the music source, the first thing I would look for is an intermittent bad connection within the subwoofer enclosure.
kfr01
Gold - Posts: 2,121
Posted: March 28, 2005 at 9:56 AM / IP Logged
Or your amplifier is temporarily going into protection mode...
New Project: 2003 Pathfinder
DYohn
Platinum - Posts: 10,741
Posted: March 28, 2005 at 10:15 AM / IP Logged
Yep, my guess would be amplifier going into protect, probably due to too low an impedence load or too high a gain setting, or low system voltage.
LeanNCut
Member - Posts: 29
Posted: March 28, 2005 at 12:36 PM / IP Logged
Stevdart,
Thanks for the responses.  Right now I'm using a cheapo 20bucks line-output converter.  Could that be the cause of this?  I don't think it's a bad connection, the speaker wires are clipped on pretty tight.
Kfr,
I'll have to check the protection mode whenever it does that again.
DYohn,
The gain is left at the amp's factory setting, the lowest.  Regarding the voltage, the voltmeter on my radar detector jumps around like crazy but never dips below 12v.  I wonder how accurate that is.
BTW, Rockford Fosgate T20001BD powering 2 T112D4 subs.  Would stock alternator, battery, and no capacitor be able to handle it?  The strange thing is when I first started playing none of this happened.  Now it does it for 15-20 mins then it's normal again.  I've only had the amp/subs for 2 weeks though.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: March 28, 2005 at 4:40 PM / IP Logged
I can assure you that there is no "factory setting" for the gain on the amplifier.  It is designed to be set based on the input signal voltage coming in and is different for every install.
As for the voltage, he is actually talking about at the amplifier itself.  You might be reading good votage off the battery, but if you have too small power wires or poor connections this could reduce the voltage the amplifier sees and create the problem you are having.  I would first suggest checking your ground to be sure it is a solid connection to shiny bare metal.
Steven Kephart
Adire Audio
LeanNCut
Member - Posts: 29
Posted: April 17, 2005 at 7:18 PM / IP Logged
Turns out it was a loose remote-on wire. How dumb is that LOL. Thanks for the help everyone.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
