05 pontiac vibe cruise control
larkster
Copper - Posts: 98
Posted: March 28, 2005 at 3:06 PM / IP Logged
has anybody done a aftermarket cruise control on the 05 pontiac vibe
larkster
Copper - Posts: 98
Posted: March 29, 2005 at 10:15 PM / IP Logged
just in case anybody wants to know it turns out all you have to do is order rostra 250-1771 it is just a factory arm after taking the airbag off from the steering wheel you just cut a hole and install the arm and plug it into a factory arm and you are done.  It is the most simple cruise install i have ever done.
NowYaKnow
Gold - Posts: 1,217
Posted: March 29, 2005 at 11:02 PM / IP Logged
The same kit is for the Vibe and the Matrix. Unfortunately depending on some of the cars specs it is not that simple on all them. You would have to add the full kit in some cases. Glad to hear you got it going!
Mike
larkster
Copper - Posts: 98
Posted: April 12, 2005 at 11:55 PM / IP Logged
how would you add a complete kit as there is no throttle cable it is all ecm controlled.  the vibe i did was the base of base units.  Have you come across one that didnt work?  how and what kind of complete kit would you use?
burnhama
Posted: April 13, 2005 at 5:24 AM / IP Logged
I have an 05 Corolla CE that uses the same 250-1771. I think mine maybe more than a switch; I think I'll at least need a clutch switch. Anyone know for sure what I'll need???
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
