Acura Intega Door Lock Frustration
styln
Posted: March 28, 2005 at 10:58 PM / IP Logged
I am wiring a bait vehicle for our police department.   The device we are using sends constant ground for lock and unlock.  I've never had a problem wiring other vehicles, but am now trying to install a 1999 Acura Integra and am having problems.
I located the correct wires and everything seem to be working fine.  Then started locking fine, but would not unlock.  I found that by some combination I still have quite figured out of unlocking the passenger door with the key and holding my tounge right I could get it to start working again.  But then after awhile I would start having the problem again.  I can't figure out why sometimes it works and sometimes it dosen't and haven't figured out exactly the combination of things to get it working again.
Do I have the wrong wires?  Or is the their something else in how the door locks funciton I need to account for?
Thanks,
Mike
Platinum - Posts: 12,488
Posted: March 28, 2005 at 11:34 PM / IP Logged
What is the wire colors & location that you tapped into for the unlock wire ? What did it meter at ? 5 volts or higher at rest ?
ejenner
Member - Posts: 32
Posted: March 29, 2005 at 3:44 AM / IP Logged
Did the central locking work ok before you started installing ??
styln
Posted: March 29, 2005 at 10:17 AM / IP Logged
The I found the unlock wire per the wiring diagram on bulldogsecurity.com ,in the driver kick panel (BLACK/ red).  I found that as it says in the diagram the wires only test using the passenger switch.  I don't show any voltage at rest.
I've played around with it a bunch more and I can't duplicate the problem on demand, but I found that when it does occur if I unlock the paseenger door with the key, turning the key twice to the left, it works normally again.
When I'm in this error condition the driver lock/unlock functions correctly, and the passenger lock works, but not unlock.  It's goofy.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
