2003 Audi A4 Alarm/Remote Start Wiring
ratmkicksass
Member - Posts: 14
Posted: March 29, 2005 at 1:15 AM / IP Logged
I Need the wiring for a 2003 AUDI A4. I looked everywhere but couln't find anything. THANKS!!!
thepencil
Gold - Posts: 1,526
Posted: March 31, 2005 at 9:06 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - AUDI / A4 / 2003 / Remote Start
[PRINT THIS PAGE]
12volts red (x2)(common 150A)   +   ignition harness
Starter RED / black   +   ignition harness
Second Starter blue or RED / black   +   ignition harness
Ignition black   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow/black   +   ignition harness
Second Accessory N/A
Keysense red   +   ignition harness
Power Lock blue/white   -   driver door module in door
Power Unlock PURPLE / green (double pulse)   -   driver door module in door
Lock Motor BROWN / blue or gray/blue   5wi driver door module in door
Unlock Motor gray/green   5wi driver door module in door
Parking Lights+ gray   +   headlight switch
Notes: May have to interrupt the purple wire at the headlight switch in order for the lights to work.
Parking Lights- N/A
Hazards RED / yellow   -   hazard light switch
Turn Signal(L) BLACK/ blue (F), GREEN/ blue (R) +   vehicle electrical system ctrl mod
Notes: The vehicle electrical system control module is under the driver side dash.
Turn Signal(R) GREEN/ blk (F), yellow/grn (R)   +   vehicle electrical system ctrl mod
Reverse Light blue/red   +   CCM, conn 3, pin 7
Notes: The CCM (Central Control Module for comfort system) is mounted on the floorpan in a protective box, under the carpet in front of the driver seat.
Door Trigger use dome supervision wire
Dome Supervision BROWN / white   -   CCM, conn 1, pin 2
Trunk/Hatch Pin WHITE/ yellow   -   CCM, conn 5, pin 11
Hood Pin BROWN / purple   -   CCM, conn 4, pin 20
Trunk/Hatch Release yellow/red   5wi CCM, conn 1, pin 6
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer NOT RED / blue or BLACK/ blue   ac   any fuel injector
Wait to start N/A
Brake Wire RED / black   +   brake pedal switch
Parking Brake BROWN / white   -   CCM, conn 3, pin 2
Horn Trigger BLACK/ white   +   driver kick, red 17 pin plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Required: Yes Type: Transponder Part #: 556U, 555B, or 555U
Notes: See DirectFax document 1056 for additional wiring information.
Be careful whose advice you buy, but be patient with those who supply it.2003 Audi A4 Alarm/Remote Start Wiring - Last Post -- posted image.
ratmkicksass
Member - Posts: 14
Posted: April 01, 2005 at 10:17 PM / IP Logged
thanks
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
